Bug? Changing one instance variant causes others to change
  • March 4, 2025
  • 20 views
Nathan Black
Currently running into an issue where changing the variant property of one of my nested instances is causing some of the other instances to change.
The expected behaviour should be that changing my variant on one instance should have no impact on the other. This is also only affecting some of the instances, which seems strange to me. Any ideas if this is a Figma bug?
Changing the “Type” property to change one of my Insight Blocks from one variant to another.
Multiple instances are changing at once after I make the selection.
