Bug: Auto layout not working with lines
  • June 13, 2025
  • 35 views
Jaro
Strange things happening when using lines in autolayout
  1. if starting a auto-layouted-frame with lines, nothing is correctly aligned
  2. if starting with rectangles and then adding a line, the rectangles work, but line still has issues
giliard
  • June 13, 2025
Lines are single "strokes" (borders), and they don't have perfect dimensions set. As you can see in the right panel, the height for the line is 0 (zero). That's why it doesn't feel right in an auto-layout.
To make them work well with auto-layout, you will need to convert them to regular shapes (like rectangles) using the "Outline stroke" option.
