AI generate image issue edit prompt
  • May 2, 2025
  • 107 views
mohssine chnaf
Recently, I started using AI to generate images in Figma, and overall it’s been working well for me. However, I’ve encountered an issue with the new image editing feature:
When I place the cursor within a word to edit, as soon as I start typing, the cursor jumps to the end of the prompt paragraph instead of staying where I placed it. I’ve tried multiple times, but I’m not sure what’s causing this issue.
ksn
  • May 8, 2025
Hey ​@mohssine chnaf! I checked in with our support team on this, and they’d like to grab more info from you. Could you fill out this form? https://figma.bot/submitreport
If you could include the following info, that would be super helpful:
  • Did it always seem to be misplacing the cursor? Has it always been doing that, or is this more of a recent behavior?
  • Does it happen when you prompt in one file, or across all files?
If it only happens in one file, can you share edit access to that with support-share@figma.com, and then include the name of that file in your submission? Our tech quality team can take a peek to see if they can replicate.
Let me know if you run into trouble doing that.
Achmad Alimin
  • July 20, 2025
Hi! That's definitely a frustrating bug - the "edit prompt" feature should work smoothly, especially when you're trying to refine your results.
I've seen similar issues reported where Figma's AI generation gets stuck or doesn't respond to prompt edits properly. A few things that sometimes help:
Quick troubleshooting:
  • Try refreshing your Figma tab and reopening the AI panel
  • Clear your browser cache if you're on web
  • Try generating with a completely new prompt first, then editing
Alternative solution: If you're still having issues and need to keep working, you might want to try Calino as a backup. It's an AI image generator plugin I built for Figma that handles prompt editing differently - you can iterate on prompts without the same technical hiccups that sometimes affect the native tool.
Since it uses a separate system, it tends to be more stable for prompt iterations and gives you multiple variations to choose from each time.
You can find it by searching "Calino" in the Figma Community plugins.
For reporting the bug: Definitely submit this through Figma's official bug report if you haven't already - the more reports they get about specific AI generation issues, the faster they can fix them.
Hope you can get back to designing smoothly! Let me know if the troubleshooting steps help or if you run into other issues.
