Body:
Hi Figma team,
In the past few days, the shortcut Shift + Command + V for pasting text without formatting has completely stopped working.
Expected behavior (previous):
While editing inside an existing text box, pressing Shift + Command + V pasted only the plain text content, inheriting the current text box’s font, size, and color.
Current behavior (now):
Pressing Shift + Command + V does nothing — no text is pasted, and there’s no response in the UI.
Steps to reproduce:
Copy some text from a another text layer.
Double-click into an existing text box in Figma.
Press Shift + Command + V.
Result:
No action occurs. No text is inserted.
This shortcut used to be a very common part of my workflow, and losing it has significantly slowed down my text editing process. Could you confirm if this is a bug or if the shortcut has been changed?
Thank you!
