Oct 8, 2025 3:29 AM UTC
What did I do and how do I fix it??
I’m having a problem with the text tool and how it interacts with the rest of my project. Previously, I would be able to hit “T”, click wherever I want the text, hit escape, and that would be it. Now, when I hover the cursor over a rectangle for example, the cursor has a little curve under it, and when I click, the rectangle just disappears. In the layers side bar, it changes the layer name from “Rectangle 2” to “text on a path.”
I tried restarting the Figma app, but it’s still doing it. I’m really not sure what I did. How do I get it back to normal?
This is the odd cursor in question.
Nellya
Power Member
Oct 8, 2025 8:41 AM UTC
This is text on path feature. To prevent the text tool from triggering on your shape, you can temporarily lock the layer.
Ally AllyAuthor
Oct 8, 2025 4:42 PM UTC
​@Nellya Is there a way to disable that? Did I somehow enable it to happen every time I want to place text near the edge of a shape? Even after locking the shape layer, it still results in the new text layer being that text on a path layer instead of a normal text layer.
Nellya
Power Member
Oct 8, 2025 4:51 PM UTC
I don’t think there is a way to disable this feature. And i don’t quite understand why your text is interacting with the locked shape. I just checked on my end, and i don’t have this issue. Could you record a video demonstrating the behavior?
Nellya
Power Member
Oct 8, 2025 5:04 PM UTC
Also, you can use frames instead of rectangles to avoid text on path feature
