Variable modes not showing in appearances dropdown
  • January 17, 2025
  • 1032 views
Chris_Hartley
I have a design system that uses 2 modes, and have recently added 7 more modes. They show properly in the Variables panel (now split between two Collections), but when I go to select them in the Variable Modes dropdown, I only see the initial 2.
Do modes only register the first created Collection? If that theory holds true, it seems like my 9 mode example below should only show 1 mode in the dropdown, and it’s still showing the initial 2.
My 2 mode structure:
themes (collection){
theme1 (mode){...},
theme2 (mode){...}
My 9 mode structure:
(For clarity, yes, theme2 moved from one collection to another below)
theme1 (mode){...}
variations (collection){
theme2 (mode){...},
theme3 (mode){...},
theme4 (mode){...},
theme5 (mode){...},
theme6 (mode){...},
theme7 (mode){...},
theme8 (mode){...},
theme9 (mode){...}
I’m using Token Studio to create the variables, but that doesn’t seem to have an impact on the result.
Thank you!
concreterichmondva
theme1 (mode){...},
theme2 (mode){...}
theme1 (mode){...}
theme2 (mode){...},
theme3 (mode){...},
theme4 (mode){...},
theme5 (mode){...},
theme6 (mode){...},
theme7 (mode){...},
theme8 (mode){...},
theme9 (mode){...}
Thank you!
It seems the dropdown only recognizes modes from the first collection. To fix this, try consolidating all modes into a single collection under "themes" and see if they appear. If that doesn’t work, refresh or update Token Studio to rule out a bug. If the issue persists, it might be a limitation with the tool.
also check this may be this will help you: https://help.figma.com/hc/en-us/articles/15253268379799-Variable-modes-in-prototypes...
