Unexpected fill override when copy/paste component
  • September 4, 2023
  • 4 replies
  • 504 views
Sergey_Tomashevsky
  1. Create a new design file.
  2. Create a new color variable.
  3. Create a new frame.
  4. Set the variable color as a fill for this frame.
  5. Create a component from this frame.
  6. Create an instance using keyboard shortcuts CMD+C, CMD+V
Result:
An instance has a color override.
When changing the fill color in the component, changes don’t appear in the instance.
Remark:
When copying a component with Option+Mouse click, there is no such override.
Yuri_Ryzhenkov
I have the same problem, the whole project got messed up because of this bug.
Celine_D
  • 3418 replies
  • September 8, 2023
Hi all,
Thanks for flagging this! Our engineering team has been aware of this issue and confirmed that this should be resolved now.
If you are still running into issues, please reach out to the support team so we can investigate further: here
Sergey_Tomashevsky
The problem is not solved. It exists in previously created files.
But it’s solved in the new files.
Julia_Shlyapnikova
Same here. It seems, not only fill settings get overrides, but stroke settings as well.
Please fix this.
