Answer
Unable to publish modified variables
  • July 27, 2023
  • 9 replies
  • 1126 views
Nigel_Faloon1
I’m getting an error that says “Publishing failed:” when I’m attempting to publish my library, it’s the modified variables that are preventing it from publishing (when I uncheck the modified variables the library is successful at publishing).
The variables in question are spacing and padding tokens. The tokens have been applied to loads of components so it’s making a real mess of my linked files!
Are there any known issues? is this a known problem? Help!!
Publish library - tokens
Best answer by Celine_
Hi all,
Our team is aware of this issue, and has implemented a fix.
Please try refreshing the file and publishing the changes now, and let me know if you are still running into issues. Thank you!
Today I tried to publish new variables to the library. But instead of the variables becoming available in the files with the library, they could not be published and now
  1. displayed in unpublished
  2. are not available in files with a connected library, an error occurs when trying to interact
  3. all updated child components lose their styles (where variables were tied that could not be updated)
How to get variables from unpublished and use them in the library?
Help me pls 😦
Jan-Henrik-Franz
Yep, I’m facing the same issue. I used Color-Variables, but unfortunately, I can’t publish the library with them. I read in another thread that this problem was supposed to be fixed, but it’s been persisting for the last 4 days.
I’ve tried using both Figma and the Figma beta client, as well as restarting multiple times, but nothing seems to be helping
Me too, and I can’t call the color variable, as soon as I click the dropdown option for the color variable in the design file, the file crashes.
Maksim7
  • July 31, 2023
Same problem. Error when updating library and crash when applying colors using variables
Jack_k
  • July 31, 2023
Having an issue with variables breaking components too!
  • August 23, 2023
Hi all,
Selvamani
  • October 13, 2023
I’ve refreshed the file. Still running issues
  • October 13, 2023
Hi @Selvamani, thank you for flagging this. We need to investigate it further to check what’s causing this, would you mind to reach out to our support team with a copy of your file here? https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include links to the file, and share it with support-share@figma.com so they can take a closer look. Thank you!
