Unable to Embed a FigJam Board within Another FigJam Board
  • May 6, 2024
  • 291 views
camel
I am trying to embed a FigJam board within another FigJam board, aiming to view and edit one board directly from within another. I recall this feature working properly in the past.
However, now when I copy the embed code via “Share - Get embed code” and paste it into another FigJam board, I receive an error message saying “Couldn’t create a preview,” and the board fails to embed.
When I paste the same embed code into other programs like Obsidian, the FigJam board embeds as expected.
What could be the issue?
  • Figmate
  • May 8, 2024
Hi @camel, Thank you for reaching out about the interactive previews of FigJam within FigJam.
I’ve tested it on my end, and everything seems to be working as expected and I haven’t been able to find any information about this error message so far.
If the embed link works in other web-based programs, it seems likely that the sharing settings or permissions are fine.
However, could you double-check the link-sharing settings of the FigJam file from which you copied the embed code? You can find more details here: Embed files and prototypes - Link sharing settings
Also, I’d like to confirm whether you have edit access to the FigJam file where you tried to insert the link preview. Please refer to the Who can use this feature section in this article: Add link previews in FigJam
Additionally, could you let us know if this issue occurs in both the web browser and the desktop app? It would also be helpful if you could check this on any other browsers you have.
If the issue persists after these checks, I suggest reaching out to our support team for further investigation here: https://help.figma.com/hc/en-us/requests/new
When contacting our support team, please include the following information:
  • Ensure you use the email associated with your Figma account.
  • Attach a video that clearly shows the issue.
  • Include the embed code.
  • Share direct links to the FigJam files (where you got the embed code and where you pasted the code), and invite support-share@figma.com with “can edit” permissions (note that this will not affect your billing).
I hope this helps! If there’s anything I’ve misunderstood, please let us know.
We always welcome additional suggestions from our community members, so don’t hesitate to chime in!
