Joshua Bock
Aug 3, 2025 2:31 PM UTC
Trouble Connecting Variant Property to Variable Mode in Figma
Hi All,
I’m learning Figma (coming from Sketch and Adobe XD), and I’m trying to build a button component with multiple variants and use variables + modes to dynamically set height.
I have create a page called Button Variants, and I have a component called Button (still learning the terminology of Figma. It has a purple hollow diamond icon), and I have 15 variants for a Primary button. I have defined the following properties and I’m using Font Awesome 7
  • Type: [Primary] {Variant}
  • State: [Default, Hover, Active, Focus, Disabled]  {Variant}
  • SizeL [Small, Medium, Large] {Variant}
  • Leading Icon: True {Boolean}
  • Icon: plus {text}
  • Button Label: text {text}
  • Trailing Icon: True {Boolean}
  • Icon2: caret-down {text}
The structure of my button compoent is:
Primary, Default, Small
├── leadingIcon (Frame)
│   └── icon (Text)
├── buttonLabel (Frame)
│   └── label (Text)
├── trailingIcon (Frame)
    └── icon2 (Text)
I have also defined a variable collection called Button Size Tokens with the following values:
Small: 32
Medium: 40
Large: 48
I then applied this variable (button-size-height) to set the height of each button variant. The issue is:
The height always uses the “Small” value, even when the variant property Size is set to Medium or Large.
What is not working:
  • I don’t see any dropdown to connect the Size variant to the variable mode.
  • The variable mode always defaults to “Small” regardless of which variant is selected.
  • When I try to link it, there’s no “Set mode property…” option in the variables panel or context menu.
  • I confirmed that:
    • I’m working in a Team Project, not Drafts.
    • The variable collection is saved and editable.
    • I can publish as a library, but I don’t see any difference.
    • Changing the default mode only affects the default height used.
What I’m trying to do
I want the button height to respond to the Size variant:
  • Small → 32
  • Medium → 40
  • Large → 48
…automatically, by linking the Size variant to the mode column of the variable. I think the is that Figma does not see the connection between the Size property and the variable.
