Table Row Action Bar on Hover
  • April 23, 2024
  • 5 replies
  • 753 views
Is there a way that when hovering a table row component that I can display a row action bar, but the row action bar does not increase the height of the row, but rather sits above the next row when hovered. I can’t seem to get it to work with autolayout.
Vishal_Ramawat
You can use absolute position on the Hover BG inside each row.
Thanks for taking a look and your time Vishal! I might be misunderstanding, but I need the buttons to overlap the row below, so the first row on hover would result in the background color change, but the buttons would sit above the second row.
Vishal_Ramawat
If you set the bounding box height of Variant2 (with buttons to Row height), it will work.
Thanks so much Vishal!! Really appreciate it.
Vishal_Ramawat
No problem Luigi. Lemme know if it worked for you.
