Craggles
Swapping colour variables on both fill and stroke together not working
Hi there,
I’m creating a plugin that:
  1. lets you pick a ‘from’ variable collection and a ‘to’ variable collection
  2. runs through your selection swapping any variables in the ‘from’ collection to the same named variables in the ‘to’ collection
It’s going pretty well, but I’ve run into a strange issue when trying to swap colour variables. Using the code below, when I run the swap on a frame with:
  • a fill bound variable – it works fine ✅
  • a stroke bound variable – it works fine ✅
  • both a fill bound variable and a stroke bound variable – it doesn’t swap the colours ❌
I’ve tried individually removing the portions of the code that tackle the fill and stroke and the same problem occurs. If I completely ignore the stroke in the code, I can swap the fill variables as long as there isn’t a variable on the stroke.
Here’s the relevant bit of the code (it also successfully swaps other variables):
if (node && "boundVariables" in node) {
// boundVariables = object
// property = property of boundVariables e.g. width, strokes, fills
// value = value of the property. could be an Array, could be a VariableAlias
type AllowedFields = 'height' | 'width' | 'characters' | 'itemSpacing' | 'paddingLeft' | 'paddingRight' | 'paddingTop' | 'paddingBottom' | 'visible' | 'topLeftRadius' | 'topRightRadius' | 'bottomLeftRadius' | 'bottomRightRadius' | 'minWidth' | 'maxWidth' | 'minHeight' | 'maxHeight' | 'counterAxisSpacing' | 'strokeWeight' | 'strokeTopWeight' | 'strokeRightWeight' | 'strokeBottomWeight' | 'strokeLeftWeight' | 'opacity' | 'gridRowGap' | 'gridColumnGap'
const boundVariables: Partial<Record<AllowedFields, VariableAlias | VariableAlias[]>> = node.boundVariables!;
(Object.keys(boundVariables) as AllowedFields[]).forEach(async (property) => {
const value = boundVariables[property as keyof object]
if (Array.isArray(value) == false) {
// this isn't a fill or a stroke
const variable: VariableAlias = value
const newVariableID = variableCheckID(variable.id)
if ( newVariableID != ""){
const newVariable = await figma.variables.importVariableByKeyAsync(newVariableID)
node.setBoundVariable(property, newVariable)
} else {
// this is a fill or stroke
let newFills
let newStrokes
if (node && 'fills' in node && node.fills) {
newFills = clone(node.fills);
for (let index = 0; index < newFills.length; index++) {
const element = newFills[index];
if (element.boundVariables?.color) {
const variable: VariableAlias = element.boundVariables.color;
const newVariableID = variableCheckID(variable.id);
if (newVariableID !== "") {
const newVariable = await figma.variables.importVariableByKeyAsync(newVariableID);
newFills[index] = figma.variables.setBoundVariableForPaint(element, 'color', newVariable);
if (node && 'strokes' in node && node.strokes) {
newStrokes = clone(node.strokes);
for (let index = 0; index < newStrokes.length; index++) {
const element = newStrokes[index];
newStrokes[index] = figma.variables.setBoundVariableForPaint(element, 'color', newVariable);
if (node && 'fills' in node && node.fills && node && 'strokes' in node && node.strokes) {
node.fills = newFills;
node.strokes = newStrokes;
} else if (node && 'fills' in node && node.fills) {
} else if (node && 'strokes' in node && node.strokes) {
Does anyone have any idea what might be cause it? Thanks for your help!
