Strange whitespace around shapes
  • March 14, 2022
  • 3309 views
Edmund_Gauci
I’m having trouble properly sizing shapes because they end up with a lot of whitespace around them.
I create a shape (StarNode, PolygonNode, or EllipseNode, then a TextNode. I resize both to the same dimensions. Then I put them into a GroupNode and finally resize the GroupNode the same.
The ellipse works perfectly, but star and polygon have significant whitespace.
While it looks alright, it makes proper sizing difficult.
Any thoughts on how I can make the size fit snugly around the shape? This is my first Figma plugin project and I’m likely missing something obvious.
I can provide the code if it will help.
Best answer by ntfromchicago
That empty space is built into star and polygon because if you change the number of sides/points, it will still fit fine in the given area.
If you don’t need that empty space any longer (and don’t plan to change the number of sides/points) flatten the node with the plugin API: flatten · Figma Developers
Flattening the node will remove the whitespace.
ntfromchicago
  • March 15, 2022
Edmund_Gauci
Thank you. Flatten is exactly what I need.
