Stop Figma pasting links
  • February 10, 2023
  • 6 replies
  • 921 views
alekstrust
Since a few days ago when I copy text from the web and it contains links, these are including when pasting to Figma even when I use CMD+SHIFT+V. I have to “hover” the text, wait for the popover, click edit and then unlink. It’s frustrating to do this every time.
Any workaround?
Best answer by Celine_
Hi there!
As a workaround, after copying your text from the web, right-click in Figma when you paste it and select "Paste and Match Style." This should remove the link from your text.
Hope this helps!
CJ_Josephs
If there is no workaround, can someone at least tell us how to get rid of the link without deleting the linked text?
Olly_the_Designer
Still needs a solution.
  • February 19, 2025
Hi there!
Hope this helps!
Olly_the_Designer
Hi there!
Hope this helps!
Thanks, is there a way to swap the keyboard shortcuts?
  • February 19, 2025
Glad to hear this helped!
To answer your question, unfortunately, it's not possible at the moment.
However, others have made similar requests regarding customizing shortcuts that may also interest you, and it’s already on our radar.
Feel free to give it a +1, as this helps our team track and prioritize developments. Thanks!
Everett Hiller
I hated it when Windows did it. I hate that Figma did it. If I wanted to paste the link and change the style of the text I would have asked. The default should be to do no harm. Don’t change my work.
