Sticky (but stop at side edge)
  • May 9, 2024
  • 1407 views
Hazelord
Is there is a way to use Scroll behaviorPosition → as Sticky (stop at side edge) instead of Sticky (stop at top edge).
If there is no feature in Figma yet, any way around it to make the same result? I want the Barang baru moves horizontally just like sticky within the frame Container barang baru.
I’ve tried to smart animate on variants 1, 2, 3 but, the last one doesn’t move the same speed since the distance is closer than 1 to 2. So yeah I need it behaves like Sticky but stop at side edge.
  • Figmate
  • May 13, 2024
Hi @Hazelord, Thank you for reaching out about applying scroll position.
Currently, we can set the Overflow to “Horizontal”, but when it comes to the Position “Sticky”, we’re limited to having it stop at the top edge.
I did a bit of digging and found a similar feature request from another community member that you might find interesting: Improve the New Position Sticky Implementation
Please feel free to check out the topic.
I’ve looked through our community resources but haven’t yet found a design file with a workaround for this.
However, with so many experienced designers in our community, there’s a possibility that someone might come up with a workaround. Let’s stay tuned for input from our experts.
Thanks again for reaching out!
