Set rotated object to 0 degrees
  • November 5, 2022
  • 4824 views
I have flipped a text field horizontally such that the Design/Rotation = 180.
When I change that object for a variation, the variation is also flipped horizontally. I don’t want this!!!
How can I keep the object flipped but reset the Design/Rotation = 0?
Thanks
  • November 5, 2022
Figured it out. I had to rotate the underlying object then flatten it.
Corinne_Prainito
Legend! I was trying to figure this out myself. Thanks
Clarissa
  • August 11, 2023
Thank you!! Had the same problem here, solved thanks to you!
