giovane.mocellin
Sep 16, 2025 12:32 PM UTC
REST API file and file nodes endpoint with pathfix rate limit error (429)
Hi everyone,
I'm developing an app feature that requires importing a Figma file and its nodes to create a hierarchy navigation tree. The goal is to register user clicks and analyze data from the Figma prototype.
My process involves traversing all possible nodes to identify those with navigation actions.
I'm running into a significant issue with large Figma files containing hundreds of thousands of nodes. When I try to process these files, I frequently hit the API rate limit and receive a 429 "Too Many Requests" error.
I've already tried a few things:
  • I switched from fetching the entire file at once to fetching nodes individually. This helped with smaller files, but the 429 error still occurs with complex designs.
  • I've checked the Figma API documentation and am aware of the rate limits, but the volume of my requests doesn't seem to exceed the typical per-minute limit. This suggests the issue might be related to the sheer size or complexity of the file itself, rather than just the number of requests.
  • I attempted to use the depth parameter to limit the file's node tree, but this isn't a viable long-term solution as I often need to go deep into the hierarchy to properly build the navigation tree.
I use Pathfix for my requests, and while I don't believe it's the root cause, I'm open to the possibility. The error seems to be directly tied to the size of the Figma file I'm trying to import.
Has anyone else encountered a similar issue with large files? Are there alternative strategies for importing and processing a file's full hierarchy without hitting the rate limit? Any help or suggestions would be greatly appreciated!
Sep 16, 2025 10:20 PM UTC
Hey ​@giovane.mocellin, thanks for reaching out!
I sent over your topic to our team to review, and right now, your best options are to:
  1. Break up any large complex files into smaller ones
  2. Instead of querying individual nodes, try to query batches of nodes. (This will reduce the overall number of requests, you'll need to make.)
Let us know how it goes!
giovane.mocellin
Sep 17, 2025 1:50 PM UTC
I've started fetching the nodes in batches already as you suggested, but still getting the rate limit error. I'm still working on it, and it looks promising. I'll keep this post updated, and please let me know if you hear anything from the team.
giovane.mocellin
Sep 17, 2025 2:11 PM UTC
​@djv is it possible to increate the rate limit?
Kristen Giovanniello
Sep 22, 2025 1:16 PM UTC
This does not work for me either. ​@djv
Can we increase the rate limit?
Sep 22, 2025 5:43 PM UTC
Hi All,
Right now, Figma's rate limits are fixed and apply to all users of the API, regardless of partnership status or use case. We're unable to provide exceptions to the rate limits. If your app is hitting the rate limits, we encourage you to slow down your requests.
