Rename layers feature (cmd+R) - Automatic Number Bug
  • September 8, 2023
  • 329 views
James_McLain1
Using the rename feature (CMD+R), why is it that when I use the Automatic number button (number ^) it always results in my components getting renamed backwards from highest to lowest?
You’d think selecting Number Up ($nn) would result in whatever I have selected getting numbered up one at a time from left to right but it does the opposite. Am I crazy?
Best answer by Ryan_52
Hi @James_McLain1 you can read a little more here about renaming layers in bulk but in short:
  • The Number button inserts a number into each layer’s name, in an ascending order.
  • The Number button inserts a number into each layer’s name, in an descending order.
Ryan_52
  • Technical Quality Specialist
  • September 8, 2023
James_McLain1
  • September 11, 2023
See I am crazy. I just realized that the layers get named in order on the layers panel. I was expecting the layers to get renamed from left to right order.
