Kenny_Lopez
Apr 11, 2024 1:39 PM UTC
Removing page node suddenly not working
I created a plugin that allows me to create pages, rename them, and pull in components for things like the cover. A few days ago it suddenly stopped working and now I get an error “Error: in remove: Removing this node is not allowed”. Its pretty much stopping right at the originalPage.remove() section but not sure why it would cause an error now.
const page = figma.createPage();
page.name = "Cover";
page.backgrounds = [{ type: 'SOLID', color : {r: 0, g: 0, b: 0}}];
const originalPage = figma.currentPage;
figma.currentPage= page;
originalPage.remove();
async function importNode() {
    let importComponent = await figma.importComponentByKeyAsync("b917533f747dd140e0922675938169c95e3f4456");
    let importComponent2 = await figma.importComponentByKeyAsync("e44e6e490be70ccc67b34702d4af234c765a020e");
    importComponent.createInstance();
    figma.currentPage = page2;
    importComponentOntoPage(page2, importComponent2);
    figma.currentPage = page3;
    importComponentOntoPage(page3, importComponent2);
    figma.currentPage = page4;
    importComponentOntoPage(page4, importComponent2);
    figma.currentPage = page5;
    importComponentOntoPage(page5, importComponent2);
    figma.currentPage = page;
    figma.viewport.scrollAndZoomIntoView([importComponent])
    figma.closePlugin();
function importComponentOntoPage(page, component) {
  const instance = component.createInstance();
  // Set the position of the component instance
  instance.x = 0; // Adjust as needed
  instance.y = 0; // Adjust as needed
  const frame = figma.createFrame();
  frame.name = page.name;
  instance.constraints = {
    horizontal: "STRETCH",
    vertical: "STRETCH"
  frame.appendChild(instance);
  page.appendChild(frame);
  frame.resize(instance.width, instance.height);
  figma.viewport.scrollAndZoomIntoView([frame]);
importNode();
const page2 = figma.createPage();
page2.name = "↳ 🎨 Designs";
page2.backgrounds = [{ type: 'SOLID', color : {r: 0.13333334028720856, g: 0.13333334028720856, b: 0.13333334028720856}}];
const page3 = figma.createPage();
page3.name = "↳ 🧰 Components";
page3.backgrounds = [{ type: 'SOLID', color : {r: 0.13333334028720856, g: 0.13333334028720856, b: 0.13333334028720856}}];
const page4 = figma.createPage();
page4.name = "↳ 🏖️ Sandbox";
page4.backgrounds = [{ type: 'SOLID', color : {r: 0.13333334028720856, g: 0.13333334028720856, b: 0.13333334028720856}}];
const page5 = figma.createPage();
page5.name = "↳ 🗄️ Archive";
page5.backgrounds = [{ type: 'SOLID', color : {r: 0.13333334028720856, g: 0.13333334028720856, b: 0.13333334028720856}}];
Sep 10, 2024 11:03 PM UTC
So, this is a new thing? I’m currently building a plugin that adds a bunch of pages and then removes them but it’s not working with the same error. First time for me…
Sep 12, 2024 6:32 PM UTC
Update: this issue is intermittent and unpredictable. I haven’t found a clear pattern, but sometimes it works and sometimes it doesn’t. I’m not sure what could cause an intermittent permissions issue…
Yash_Deshpande1
Mar 21, 2025 12:42 PM UTC
I may have figured out why this is happening.
Lets call the page you are trying to remove a PageNode: pageToRemove, and a page you may want to keep PageNode: pageToKeep.
let pageToRemove = figma.getNodeByIdAsync('some-id')
let pageToKeep = figma.getNodeByIdAsync('some-id')
Figma does not let you delete the page you are currently on. You may have recognised written the following:
figma.setCurrentPageAsync(pageToKeep);
pageToRemove.remove();
This method is causing a race condition, i.e. due to the async nature of your request, your first command is being run after the second command. To fix this
figma.setCurrentPageAsync(pageToKeep).then(()=>{pageToRemove.remove()})
