I am a brand new figma user, I am trying to understand if there is a workflow comparable to that used for creating indesign template slides with frames. I want to add a “frame” to a template slide so that a different image can be uploaded to each one while maintaining the same position across slides.
thanks
As a workaround, you can insert a dummy image on a page in your slide, resize or position that image, then simply duplicate that page and replace the image.
If you're looking to create a template out of it, you will need to publish it and then have that custom page on your newly published slide.
I couldn't find a way to update or add a custom page design to the slide you're working on, and as far as I can tell, even the "blank slide" is a predefined template made by Figma.
