"Publish Library" detaches local instances. After trying restore component & trying to publish again - same issue comes up.
  • April 24, 2025
  • 32 views
Yash1623
I have a file with a single component. Every instance can be followed to the main component in the documentation present in same file. I want to publish the file library so later I can Cut+paste it into another component library.
On the last step before publishing I have “Added (?)” message next to a few components (that work before publishing) saying:
“This component was moved to another file. Publishing this new copy won’t update instances in other files.”
The component wasn’t moved to another file. After publishing the library despite this message all local instances are detached and my only option to follow back to a component is to “Restore main component” - but the component was there anyways. When I click on “Restore main component” it places the same component on top of main component that was previously present.
When I delete the one that doesn’t work and publish the library again, same thing happens. I’ve added 20 components like this but did not face this problem. Faced this problem in only 2 components.
How can this issue be solved?
  • Figmate
  • April 25, 2025
Hi ​@Yash1623, thanks for reaching out!
I understand you're seeing a message that doesn't make sense when you're trying to publish. That sounds frustrating, and thanks for taking the time to tell us what you've already tried.
To best understand and resolve this, it would be really helpful for us to take a look at the actual file. So, I'm going to create a support ticket for you with the information you've given us. Our team will be in touch with you directly to help you with this. You’ll get a message about the new ticket. It'll go to the email address we have for your account.
Once you receive it, please reply with a link to the affected file and a screen recording showing what you're seeing. That would be super helpful for us!
Thanks again for getting in touch.
