Prototyping Issues
  • July 8, 2024
  • 5 replies
  • 139 views
Karachi
When I start the prototype, only some of the elements of the design show up. The rest is blank. How do I fix this?
Vishal_Ramawat
Those elements might be ‘floating’ over the frame and not actually nested in the frame being rendered.
Karachi
  • July 9, 2024
How can I tell the difference?
Vishal_Ramawat
When you select any element, check the left Layers Panel, they should be inside the Parent/Main frame. For e.g.
The ‘Fly’ instance looks like it is inside the Frame 1, but if you see Layers Panel, it is outside of it.
Karachi
  • July 11, 2024
I think the issue was that I was using sections to house some of the elements. I replaced them with regular boxes and that seems to have fixed the issue.
Thank you for your help.
Hiba_Fathima
Hey, if you want to create interactive product demos directly from Figma, you can also check this Plugin we built - https://www.figma.com/community/plugin/1382781944686485388/supademo-create-interactive-prototypes-from-figma
It helps you create interactive prototypes in < 5 mins
