Prototype links problem
  • May 11, 2023
  • 248 views
Hello I hope someone can help me. When I click on the frame to connect it to another frame it automatically puts the arrow to a sort of invisible section and I can not connect it to any frame. How come?
  • May 12, 2023
Hi @Marianna_Di_Gregorio ,
The behavior sounds odd. You should be able to connect a frame to another frame with connection.
More information with our Guide to prototyping in Figma : here
To create connection:
  1. Select the hotspot for the connection.
  2. Click to create the connection.
  3. Drag it to the destination.
  4. If there are no existing connections, Figma will make the first frame a starting point
If you are still running into trouble, could you share a screenshot or a copy of your file, so the community can have a better look at it?
