rob-redbar
Jan 12, 2023 7:15 PM UTC
Promise-based messaging between plugin and ui
Does anyone know of a way to do promise-based messaging between the plugin and the UI? (@Gleb 🙂)
Using the globals:
parent.postMessage(...) → figma.ui.onmessage → figma.ui.postMessage(...) → window.onmessage can lead to spaghetti code… promises would be so much cleaner.
Really only the UI → Plugin direction would be fine, e.g.:
someCoolMessaging.post(type: 'get-some-data', payload: { id: 5 }).then(data => {
    console.log('got some data', data)
.catch((error) => {
  console.log('error getting data from plugin')
Power Member
Jan 13, 2023 2:40 AM UTC
rob-redbar
Jan 13, 2023 3:02 AM UTC
figma-messenger seems to be just a type-safe version of 1-way comms, but html<->script I/O seems to have a way to do async/promises. Will try it, thanks!
Michael_Yagudaev
Jan 19, 2023 1:22 AM UTC
I’ve created a library for it, and maybe I should publish it. It is built on top of Utilities — Create Figma Plugin with 3 basic primitives: req, res and subscribe.
I should probably publish it too.
This emit utility will help a lot. Any mechanism that abstracts iframe <=> iframe communication will help too.
In any case, what you are asking is
// ui.js
await Main.drawRect()
// main.js
function drawRect() {
  const rect = figma.createRect()
From what I’ve seen no other library currently supports this.
Jakub Hajduk
Mar 11, 2025 3:46 PM UTC
Hello,
in case someone is still looking for an solution to communicate UI and plugin code, I wrote figwire - lightweight, TypeScript-friendly library for seamless communication between Figma plugin and its UI.
 https://www.npmjs.com/package/figwire
Jay Bee
Aug 13, 2025 6:13 AM UTC
​@Jakub Hajduk Thank you for your hard work! I loved the API and your code structure. I’ll be using it in my next plugin.
Jay Bee
Aug 16, 2025 11:49 AM UTC
Just wanted to report back saying that using Figwire + Zustand gives an incredibly powerful and flexible DX. It’s all promise-based and you can even send messages from the plugin to the UI with ease to be consumed by React. Figma should seriously consider integrating a similar mechanism into the regular workflow. Highly recommended. 🤟
Jakub Hajduk
Oct 20, 2025 11:33 AM UTC
Awesome to hear that! I’m very glad you liked it. ;).
