Problems with Design Mode on Figma Slides
  • June 27, 2024
  • 14 replies
  • 1587 views
Paul_Boag
Is anybody else getting the following error when they try and use the design mode in Figma Slides:
Figma slides design mode requires a Figma design plan
And yes, before you ask, I am logged in on an account that has a design plan seat.
Paul_Boag
  • June 27, 2024
Just to let you know if you have the same problem, the issue is caused when you create the slides in drafts rather than a team/project. If you create it in there everything works fine.
I was also having this issue. It automatically switched to design mode when I started manually adjusting some auto layout spacing on the slide—but now it won’t let me toggle back. I quit and reopened and it went back to slides mode but now I’m getting that design seat error again. I’ve moved it out of my drafts but that hasn’t seemed to fix it 😦 It seems like the toggle is just buggy?
  • June 28, 2024
Hi there,
Thanks for flagging. I’m checking this behavior with internal team and will get back to you once I have any updates that I can share with.
Thanks for your patience!
Toku
Russell_Phillip
Figma Slides needs a lot of work… I tried using it. It’s literally easier to design a presentation in Figma, not Slides.
Eliot
  • June 30, 2024
@Paul_Boag I just experienced this issue as well but was able to fix it by duplicating the Slides file and working from the duplicate, immediately the toggle worked again. Before that I tried logging out and reinstalling Figma to clear the cache but that didn’t fix it, had to duplicate the file and then deleted the original.
  • July 1, 2024
Hi all and @Ali_Doucette ,
Our apology for the confusion. Our team confirmed it was a bug and they fixed it. If you still see this issue, please feel free to let us know!
Toku
Awesome thank you Toku! Slides is so great, I’m a big fan!
  • July 2, 2024
Still having the same issue
  • July 4, 2024
Can you try this?
Figma Learn - Help Center
I hope this clarifies it!
Toku
I have the same problem. I have moved my file to the team project. But it still doesn’t work and show ‘Design mode requires a Figma design plan’.
  • July 9, 2024
Hi there,
Do you have a full seat for Figma Design? To access Design Mode, a full seat is required:
If you have the seat but you can’t access Design Mode, could you reach out directly to the support team: https://help.figma.com/hc/en-us/requests/new? Please make sure you use the email associated with your Figma account.
Thanks!
Toku
Ortega_Matthew
Was just thinking the same. I actually find it nicer to just design in a regular design file, and then keep the presentation space clean and not require design mode. Other things feel weird to not include in Slide mode? Not being able to adjust the Layout Grid? Is that really a paying feature?
Hugo_Frade
  • December 3, 2024
Hi there, this issue just happened to me right now. Can you check if another bug affected the switch?
  • December 3, 2024
Hey @Hugo_Frade, sorry for the trouble!
We’re experiencing a service disruption right now that may be affecting this: https://status.figma.com/
