PDF exporting
  • December 4, 2024
  • 6 replies
  • 273 views
Wouter_Moonen
Hi Community! When exporting PDF files the color changes to grey when importing it to Pandadoc. Do you know why this happens? It starting doing this since a couple of weeks now. When I import an older PDF export from Figma in Pandadoc i don’t have this issue.
See screenshot:
Gayani_S
  • December 6, 2024
Hey @Wouter_Moonen, thank you for sharing the screenshots and bringing this up. It sounds like this might be related to color management settings. Could you try switching your color space? For instance, if you’re currently using sRGB, try changing it to Unmanaged (or vice versa), restart Figma, and then check if the colors export correctly. You can find detailed steps here: Color management in the desktop app.
If the issue persists, here are a few additional steps you can try:
  • Check if the problem occurs with different files or only with specific ones.
  • Test the PDF in another viewer or application to confirm if the issue is specific to Pandadoc.
If none of these steps resolve the issue, let me know, and I’ll be happy to look into it further with you.
Wouter_Moonen
Hi @Gayani_S , thanks a lot for getting back to me! I’ve tried the steps you described and it turns out that some of the designs have the issue and some of them don’t. I don’t know how or why this is, but some of the settings of the document aren’t correct. Do you know how to fix this?
Gayani_S
  • December 13, 2024
Hi @Wouter_Moonen, thanks for getting back to me!
To clarify, are you noticing the colour change right after exporting the PDF from Figma, or does it only happen after importing the PDF into Pandadoc?
Have you tried importing the PDF into other tools to see if the issue persists? If the colours appear correctly elsewhere, it might point to an issue with Pandadoc.
If you’re experiencing the same issue across multiple tools, I can escalate this to our technical quality team for further investigation. Let me know how it goes!
Wouter_Moonen
Hi @Gayani_S , I’m experiencing it only when importing the files to Pandadocx. So what I mean by this is that all the files, when exporting, arent facing any problems. But when I import them to PAndadocx, than I get this issue.
With other tools I don’t have this issue.
Gayani_S
  • December 30, 2024
Hey @Wouter_Moonen, thank you for clarifying!
From what you’ve shared, it sounds like the problem is specific to Pandadoc, this might be something related to how Pandadoc is processing or rendering the colors in the newer files.
I’d recommend reaching out to Pandadoc support to see if they’ve made any recent changes to how they handle PDF imports. They might be able to provide clarity or even suggest a solution.
If there’s anything else I can assist with, whether it’s related to exporting settings or troubleshooting further, please don’t hesitate to let me know. I’m here to help!
evansfielder
  • January 22, 2025
OP did you ever find out a solution to this? We’re facing the exact same issue, same use case. Files created & exported out of Figma > upload to PandaDoc > PandaDoc strips the color to black/grey. Its only certain pages and for our doc, it seems to be linked to gradient colors perhaps (hoping this forms a clue).
