Pasting bitmap image from illustrator doesn't work
  • July 22, 2023
  • 990 views
andrea-hg
Trying to migrate a very graphic slide deck from illustrator to Figma. I have no problem copy-pasting vectors, but bitmaps are just pasted as an empty frame 😦
I’m afraid I’ll have to export all assets as png first and then import them into figma, but that takes up considerably more time than just copy-pasting 🫠
Is this normal behavior or anyone else having this problem? Is there an easier workaround??
Best answer by andrea-hg
Solution: It actually had to do more with Illustrator than with Figma. To copy & paste bitmaps from illustrator to Figma with ease, the ‘include svg’ setting (under clipboard handling) must be unchecked.
  • July 24, 2023
Hi @andrea-hg ,
For your information, to double check: SVG Symbol, marker and clipPath elements are not currently imported. You can find more information here: https://help.figma.com/hc/en-us/articles/360040030374-Copy-assets-between-design-tools#Import_to_Figma
andrea-hg
  • Active Member
  • September 5, 2023
