Paste and replace not working as expected
  • December 16, 2024
  • 17 replies
  • 438 views
Ty_Fairclough
Possible bug:
Currently, when I use the paste and replace option (either via keyboard shortcut of the menu options), instead of the thing I copied replacing the thing I selected, the text of the thing I copied replaces the thing I selected.
I need it to work as before, where the entire thing I copied (component, section, frame, etc) replaced the thing I selected.
There are a few older posts regarding the copy and paste+replace; however, I believe my experience is novel.
Marlena
  • December 18, 2024
Same here! Did you find solution?
  • December 19, 2024
Hello @Ty_Fairclough @Marlena
Could you share a video recording or the file link with access granted to support-share@figma.com? It won’t affect your billing. I hope to investigate this further.
I tested it on my end but couldn’t replicate the issue.
Toku
Hsu_Chihwei
  • February 7, 2025
Experiencing the same issue, it only replace with the text instead of the whole symbol I copied.
  • February 7, 2025
Hey ​@Hsu_Chihwei, sorry to hear this is happening!
Are you right-clicking your selection then clicking Paste to replace from the right-click menu or using the Paste to replace keyboard shortcut? What OS are you using? And is this happening in both the desktop app and the browser?
As asked previously, are you also able to share a screen recording or a file link shared with support-share@figma.com, so we can take a closer look?
Hsu_Chihwei
  • February 8, 2025
Hey ​@dvaliao, thanks for response.
Both shortcut and right-click don’t work, and it only happens on the browser.
Here is the video: https://drive.google.com/file/d/1S5pvr2emGuncS7hvatS1F3PX-4xeQDzH/view?usp=sharing
StanleyJames
  • February 8, 2025
That sounds frustrating! It seems like the paste and replace function is behaving differently than it should. Have you tried restarting the software or checking for updates? Sometimes, a quick update or reboot can resolve unexpected issues like this. It might also be worth exploring the settings to see if something there is affecting the behavior. If the issue persists, reaching out to support could help—hopefully, they can get it sorted out for you! Let me know if you find a fix!
Hsu_Chihwei
  • February 10, 2025
Reboot did’t work, and it happens on web version so I am not able to update it. 🙂
  • February 19, 2025
Hey ​@Hsu_Chihwei, thanks for your patience!
Our team confirmed that this is a bug, and they’re proactively investigating to reproduce and fix the issue. We’ll provide an update on this as soon as we can.
katterheinrich
Any update here? I hadn’t experienced this bug until this week (Mon March 24, 2025). Exactly as OP described where plain text is pasted instead of the intended behavior where a frame/component is replaced with all styling intact.
Hsu_Chihwei
  • March 27, 2025
This issue recur today, I had no problem to use the short cut for several weeks.
Abby Moffitt
  • March 31, 2025
This issue has been happening for me all day.
Bob_Juranek
  • March 31, 2025
I have been experience this issue too, and it has been incredibly frustrating.
Carmen Chimiski
I have also experience this issue for the last 3 days, it works selectively.
I’m hoping someone can help me find a solution. The issue happens both in the browser and the Figma app, so I’m not sure what’s going on.
Here’s what’s happening:
  • When I try to copy and paste images into a selected frame, Figma often picks up the wrong content—the last thing I copied instead of the current item.
  • The Paste and Replace option (via keyboard shortcut or menu) isn't working correctly either. Instead of replacing the selected item with the copied image, it replaces the selected item with the text of whatever I copied last.
There are moments when it works as expected, but for the most part, it’s not functioning properly. I’ve tried restarting Figma and switching between the browser and app, but the issue persists in both.
if anyone has any suggestions on how to resolve it? I’d really appreciate any help!
Thanks in advance!
Hsu_Chihwei
  • April 3, 2025
@dvaliao looks like many of us are struggling with this recurring issue.
  • May 21, 2025
Hey All, thanks for your patience and understanding!
The team recently launched a fix for this. Please refresh your tabs and let us know if you run into any further issues.
Jan M
  • August 19, 2025
Hey All,
so for me it still doesnt work as I would expect it to work but maybe Im also not understanding the feature properly.
I want to replace an image and this works fine but instead of keeping the Position settings of the Image I want to replace it pastes the rotation and relative position of the Image im Pasting.
Im using copy/paste properties to make it work but I dont know if its suppose to work like that, but as I said im new to this and maybe I just dont understand the correct workflow.
youngyoung
  • August 26, 2025
Paste and match style, this whole shortcut isn’t working for me on broswer (worked with right click)
Please look into it and fix!! THX!
