Paragraph spacing do not work
Hello, i have a big problem !
When i’m changing my paragraph spacing in my text style, it doesn’t change my text… In my example, you can see i set the paragraph spacing to 91 (huge spacing) but i still have a kind of 20.
It’s working for other properties. I’ve restart Figma but still have the issue.
Please help me, thank you
  • 2518 replies
  • November 27, 2023
Hi there,
Thanks for flagging. I will check this behavior with our internal team and will get back to you once I have any updates.
Toku
  • 2518 replies
  • November 28, 2023
Hi there,
Our engineering team confirmed it was a bug, and they fixed it. Once you reload the tab, it should be fixed. I confirmed it on my end, but if you keep seeing the issue, please feel free to let us know. Thanks again for flagging!
Toku
Juliana_Vimmer
Im having the same problem, the paragraph spacing simply does not compute
Iberedem_Harry
Yeah i had the same problem except what you have to space should actually have a paragraph in it. so you should use ‘Enter’ for a next line then try the feature again… 😉
  • February 6, 2024
Oh! Thank you for your tips!!
Aditi_Sharma1
I have the same issue, I came here to find a solution, but turns out its a bug?
Bas_Schellekens
got the same problem, seems bugged still
  • 2518 replies
  • May 23, 2024
Hi @Aditi_Sharma1 @Bas_Schellekens ,
Thanks for reaching out. Could you share the screenshots or screen recording so we can understand the issue correctly? Also, your working environment such as OS, browser etc would be helpful!
I tested it on my end and it looks working properly at the moment.
Thanks!
Toku
Laura_Elizabeth
Hi, I’m having the same problem (I’m on the latest version of Figma). I have noticed that it doesn’t work if there are multiple paragraph styles in the same text box.
See this video: https://vimeo.com/966629322/5beebad5e0?share=copy
I’m on Mac OS if that helps.
  • 2518 replies
  • June 25, 2024
Hi there,
Thanks for sharing the details! It could be a bug. Could you submit a bug report detailing the steps that led to this issue? You can do so by following the link:
Figma Learn - Help Center
Thanks again!
Toku
Laura_Elizabeth
Done, thanks!
Paul50
  • July 15, 2024
Same problem here. Changes to text styles don’t apply when there are multiple text styles in the same text box.
KelseyONeill
Bump. same issue here. Must be a new bug, cause I know I have had different styles in one box before.
  • 3582 replies
  • July 30, 2024
Hi everyone, we appreciate your patience! Our engineers have looked into this further and determined that this behavior is due to a feature limitation. Figma uses the style on the first character in the text box to set the paragraph spacing for the entire text box. We have submitted a feature request to bring this to the attention of our product teams.
Thank you once again for bringing this up and for your patience!
Julija4
  • 10 replies
  • August 12, 2024
I have the same issue. I found out that this issue only occurs if you copy paste text. If you type the text manually into the text field the paragraph spacing is working.
A little bit ridiculous 🫣
Malte_Euler
Hi,
When i have multiple styles in one textbox, the values of the first Style will override the others, so if a H2 is in at the start, that maybe has 0 paragraph spacing set, it will override following styles. Changing the paragraph spacing setup for the headline changed the styles for following paragraphs as well. its a hack, but for me it worked.
