Need to constantly set containers to fill or left and right constraints after making changes
cyrezeraser
What I’ve noticed in Figma is if I set up some layers to have auto layout, set them to fill and then left + right constraints, it works fine when you resize the artboard.
However, if I were to make this auto layout frame a component, or take 2 auto layout frames that are already responsive and then combine them into another auto layout frame, I have to reset these parameters again and again to be fill container and left + right constraints.
Why isn’t there a way to default to using fill container and left + right constraints when I make it a component or combine two auto layouts into another auto layout? It makes the user constantly have to readjust the resizing parameters which is really annoying and time consuming over the long term.
