_Eric
Sep 12, 2024 9:00 PM UTC
'module' is not defined
I can’t seem to figure out why I’m getting this console error when trying to run my plugin:
vendor-core-98e7eff694049858.min.js.br:15 ReferenceError: 'module' is not defined
    at <anonymous> (PLUGIN_21_SOURCE)
    at <anonymous> (PLUGIN_21_SOURCE:1)
    at call (native)
    at <eval> (PLUGIN_21_SOURCE:3)
webpack.config.js
// webpack.config.js
const path = require('path');
const HtmlWebpackPlugin = require('html-webpack-plugin');
module.exports = (env, argv) => {
  const mode = argv.mode === 'production' ? 'production' : 'development';
  const devtool = mode === 'production' ? false : 'inline-source-map';
  return [
      // Plugin code (Main Thread)
      mode,
      devtool,
      entry: {
        code: './src/code.ts',
      module: {
        rules: [
            test: /\.tsx?$/,
            use: 'ts-loader',
            exclude: /node_modules/,
            test: /\.html$/,
            use: 'raw-loader',
      resolve: {
        extensions: ['.ts', '.js'],
      output: {
        filename: '[name].js',
        path: path.resolve(__dirname, 'dist'),
      // Plugin UI
      mode,
      devtool,
      entry: {
        ui: './src/ui.ts',
      module: {
        rules: [
            test: /\.tsx?$/,
            use: 'ts-loader',
            test: /\.css$/,
            use: ['style-loader', 'css-loader'],
            test: /\.html$/,
            use: 'html-loader',
      resolve: {
        fallback: {
          fs: false,
          path: false,
      output: {
      plugins: [
        new HtmlWebpackPlugin({
          template: './src/ui.html',
          filename: 'ui.html',
          chunks: ['ui'],
          inject: 'body',
Pretty new to plugin development so not entirely sure even what to look into. Any guidance would be insanely helpful!
