Missing Justification Options?
  • September 29, 2022
  • 7 replies
  • 12261 views
Noe_St-Onge
Hi, we need to apply justification to every lines on a paragraph (including the last one).
You see we are used to have those options in Illustrator:
  • Justify with the last line to the left
  • Justify with the last line centred
  • Justify with the last line to the right
  • Justify with the last line justified as well
    But Figma only seems to support - Justify with the last line to the left.
Did we miss something or it’s a known limitation in Figma ?
Is there a work around that exists ?
Thanks !
Noe_St-Onge
Here is a screencap of the option available in illustrator we’re trying to replicate in Figma.
Screen Shot 2022-09-29 at 10.30.22 AM
tank666
You can find all existing alignment types in the Type settings panel.
Figma Help Center
Noe_St-Onge
Thanks for your replie. You see I went through these explanations before and it seems that what I’m explaining above is not available by default in Figma. But my question is :
Is there something we might have missed in Figma’s functionalities that could help me justify the last line of a paragraph or is there any plugins/work around that could achieve that?
Thanks !
Noe_St-Onge
The Justify button only seems to achieve a justification with the last line to the left.
I would like to justify the last line as well !
tank666
Since there are no alignment types other than those mentioned in the help article above, you won’t be able to create them in any way until the Figma team makes them native functions and adds an API for them.
Sinead_Easdon
I would also really love to have the full set of justified text options that we have in Illustrator, InDesign etc. Does anyone know of a plugin capable of achieving this style of formating?
Fingers crossed the Figma team adds them to the native functions!
exkpwn
  • August 16, 2024
So did you find any?
