It’s not clear from your description whether you’re using the Plugin API or the Widget API because you’re referring to both. Where are you seeing this error: in the Figma Desktop app console or in your IDE?
Unfortunately, there is still not enough information. What ways have you tried? Have you updated your typing files? What is the structure of the node that you want to change the property on? What node is this? Is this node an auto layout frame? If it’s not an auto layout frame, is it nested within an auto layout frame?
I’m seeing the error in my IDE.
I’ve tried adding the maxWidth to:
- Autolayout (various levels of frames and nesting - top to bottom)
- Text w/in an Autolayout
I’d like to have the maxWidth applied to that widget.Text name=“ActText” in conjunction with the width={“hug-contents”}, which I can do in Figma itself, but seem unable to translate to the code.
I think we’re trying to use the widget api!
We’re trying to build a plugin and using the widget API. When using the Text
component, it seems we can’t use the maxWidth
prop on it. We’re tried updating both widget and plugin api in our package.json file to 1.77.0 and 1.8.0 respectively
Apologies, i meant we’re building a widget* not a plugin
Thanks for bringing this up. I’ve reported this issue internally.
