Listening for changes using figma.on()
  • April 17, 2023
  • 1035 views
aamir.shaikh
I want to change my plugin UI when the selection changes in the editor.
This is the code I am using to listen for changes in my code.ts file:
figma.on("selectionchange", () => {
  figma.ui.postMessage(selectedTextNodes.length)
And this is the code I’m using to receive the changes in ui.html:
onmessage = (event) => {
    document.getElementById('layers-selected').innerHTML = `${event.data.pluginMessage} text layer${event.data.pluginMessage === 1 ? '':'s'} selected`
However, this isn’t working. Am I using a wrong approach? If so, what would be the right one?
tank666
  • April 17, 2023
The code snippets shown work as expected. Check the code you didn’t share.
aamir.shaikh
Thanks. The bug was that I was sending the variable v=value, which was declared when the plugin first ran.
Instead, I should be sending real time ‘value’, and not the previously defined variable.
