Library styles and variables are not being listed in panel
  • March 14, 2024
  • 10 replies
  • 753 views
ozgurgunes_vl
Styles and variables are being listed only if “All libraries” option is selected. When I select a library it spins forever. Even if I create and publish a new library and go to a new file, nothing changes. Anyone having this? This started with last update I guess.
Best answer by djv
Hey All, so sorry for the trouble!
This was a bug that we discovered early yesterday morning, but we’ve already pushed a fix. Please refresh your tabs and let us know if you run into any further issues.
Matt_Girardi
My team is having the same issue
Marcus_Chadwick
I am having this issues today also
Andela_Dev
Same here
Screenshot 2024-03-14 at 13.56.29
luisa.scaletsky
We are having the same issue here
Captura de Tela 2024-03-14 às 16.43.14
allanmgoncalves
I’m having the same issue here (Mac Pro M1), but my friend with a Mac Pro M2 was having this problem just now but his is back to normal, after reloading all the tabs.
allanmgoncalves
I’ve reset the cache, I’ve asked you to reload the tabs
allanmgoncalves
After updating mac os to 14.4 Figma is back to normal
  • March 15, 2024
laurel.ch
  • December 6, 2024
Draft I just found from June: I am having the same problem, and it’s June. I just updated Figma yesterday. I am not seeing styles under “All Libraries” and in fact am not able to change libraries at all.
And now it’s December and I’m saying: I am STILL having this issue, but inconsistently. The same file where I created the styles is having the issue and not showing those styles in the Library.
I discovered that Variables were cumbersome for my current usage and were creating more problems than solutions, so I deleted all of them. The only thing I want to use for my current project is styles. However the “Libraries” tab seems to think only Variables are valid! Please allow us to pick our core styles from here as well!
I need my styles for using Drop Shadows as outer strokes which work with inner strokes (since you don’t let us do this yet – I mean, to be fair I am still using the old version because I haven’t had time to learn a new interface), and I do NOT use variables for this. I just need to use a color style.
Nicole_Emenhiser
Just here to report that this is still an ongoing problem despite the approved response.
