Hi,
Our team doesn’t really use libraries because our experience with them wasn’t great. Recently I’ve decided to give it another go after quite some time because we are at a state where we must split files in order to reduce the memory usage of the file.
Unfortunately, 10 minutes later I ran into an issue that is driving me crazy for the past 10 hours.
What I did:
- Created a new file called “Design System:
- Created a new component called “Button” with two variants “Default” and “Hover”
- Published the changes to the Library and published the Library
- Created a new file called “Screens”
- Added the newly created Library to the “Screens” file and added the “Button” component
What the issue is:
- The “Button” component default state is “Default”. When changing it to “Hover”, literally nothing happens. I can’t figure out for the sake of me what’s happening.
Any ideas?
Thanks
Page 1 / 1
Hi
Thanks for providing the detailed steps. I tried following the same steps, but I wasn't able to replicate the issue on my end. Could you please share a video recording if possible? This would help us better understand the situation and investigate further to determine if we can reproduce the issue.
Thanks!
Toku
