hey everyone, I am new to Figma and I was designing an interactive text field that switches between states (enabled ,hovered,focused ,error) I chose to insert this component from Google Material Design and I chose the prototype trigger between focused state and error state to be pressing ‘Enter’ button and when I present the whole form the text field freezes in focused state though I press ‘Enter’ .
here is a photo of the variants with prototypes.
Thank you in advance.
Page 1 / 1
Hi there,
Thanks for reaching out. I tried to test it on my end with a simple text field, and it seems to be working fine like below:
I’m interested in how you’ve set up the triggers and interactions for the prototype. It looks like you’re using the “Mouse Up” trigger, and I’m wondering if that might be causing the freeze. I’m not 100% sure since I haven’t checked your file.
If possible, would you be able to share the file link with access to support-share@figma.com? It won’t affect your billing. I hope I can investigate it further.
Toku
