I’m running into an issue with a component that uses a slot. When I replace the slot content with an instance of a different component, the padding of the original slot component is preserved instead of inheriting the padding from the new component.
I expected the replaced component to behave with its own padding settings, but it seems the slot’s container enforces its own padding.
Is there a way to make the new component respect its own padding instead of inheriting it from the slot container?
Any suggestions or workarounds would be greatly appreciated!
It seems like the slot itself has padding overrides so when you swap it these overrides persist. I would make sure that my slot placeholder does not have ANY overrides to prevent unwanted behaviour when swapping instances
