Is there a way to identify all unlinked text styles and auto-assign it to an existing/matching text style?
  • August 12, 2022
  • 11 replies
  • 3733 views
Rene_Tan
Context
migrating to a client’s figma environment, we’ve imported the text styles but in bringing the design flows over, everything is unlinked. Would like to have everything relinked in the new project.
Thanks!
Maxime_Daraize
Hello Rene, you might want to take a look at this plugin. It give you the ability to « SYNC » your Color or Text styles to elements with matching properties.
Sync Style Plugin
Hope it help ✌🏼
Rene_Tan
  • August 17, 2022
Thank you Maxime, I will have a look at this plugin. I appreciate the help! 🙏
Rene_Tan
  • August 18, 2022
@Maxime_Daraize Thank you again for referring me to that plugin, I’ve tested it and it works great for established color styles. Though when I run it for text styles, it tells me x-amount of styles applied but upon inspection the text styles aren’t actually applied. Have you run into this? Maybe a bug in the plugin?
Thanks again!
Maxime_Daraize
@Rene_Tan
Hello, thank you for the feedback.
I didn’t run into that issue so far, would you be able to maybe share a link of a « test file » with the specific text styles you tried to apply. It would help me to investigate and resolve the issue.
Thanks again
P.S.
If you can’t share a link, could you share the properties of the text styles
Rene_Tan
  • August 19, 2022
Thanks @Maxime_Daraize 🙏
For context, I’ve pulled a sample set of typestyles in, and then I’ve copied over a component that should be leveraging a few of those styles.
Funny enough when I run it, it is not identifying any instances to apply the styles at all. Here is a link to my test project, thanks again!
Maxime_Daraize
No worries & thank you for the link 👌
So I had the same issue, when I tried to use to plugin or simply associate one of the text style to a text element manually. (Which is odd).
What I found, is that the font-family and the font-style were missing (not installed).
I think this is why we run into that issue.
When I changed to font-family& the font-style. I was able to use the plugin & associate style to element without any issue.
Maybe, if you have those fonts, tried to install them so Figma can recognize them.
See images below.
Screen Shot 2022-08-19 at 10.23.33 AM
Screen Shot 2022-08-19 at 10.24.14 AM
Rene_Tan
  • August 19, 2022
Gotcha, I will try to see if I can find a way to install them locally as I’m using adobe’s cloud type library,
One thing I’ve observed though was that if I let’s say create a new unlinked text field with the same properties locally, or if I duplicate the instance that was assigned a style then detach it, the plugin works to match/reassign as expected – so I’m not sure how that plays with the cloud fonts but will keep you updated!
Rene_Tan
  • August 19, 2022
Strange, so it make some time to see if I can get the fonts locally for Museo. But I tried it with a font family I know I have installed locally, Gotham. I ran the plugin, it says x number of styles were applied but when I click those text fields they aren’t truly assigned.
Maxime_Daraize
Hey, thanks again for your feedback.
So after few tests, I realize that it dosent work properly with locally installed font. My guess is the plugin dosent recognize font outside from the fronts included in Figma.
I’ll try to figure out a way to make this work. Thank you again for discovering this bug.
I’ll keep you in touch,
Rene_Tan
  • August 23, 2022
Thank you so much for the support, hopefully we can find a solution @Maxime_Daraize! 🙏💯
Anna_Geils1
@Rene_Tan Have you solved this issue? I am having the same problem and the plugin does not work for texts, exaclty like you described it. I am a bit desperate. Would be great if you could help.
