Is there a way to change the name by removing spaces in a large number of layers at once?
  • March 22, 2025
  • 63 views
umifi
Hello.
I have a lot of icons with different names and spaces in them.
I need to remove the "Pixel/Solid/" in the name, leaving only the final name of the icon, and also remove the spaces where they are present.
I read the information about renaming, and there was an option with variables, but after trying it, nothing worked for me.
Best answer by umifi
I found a solution.
If it's useful to someone, then selecting all the layers, pressing Ctrl+R will be "Match" on top, enter everything you don't need in the name and don't enter anything in the "Rename to" field. Then it just deletes what is not needed. It also works with a space bar.
umifi
  • March 22, 2025
I found a solution.
