Is instance.mainComponent.key the same as the component.key
  • February 27, 2024
  • 199 views
Hello.
I am able to get the main component key of an instance, but when I get the component key (of the main component from the library). the component key is returning a different value.
I’m trying to compare the instance with the library component key to see if they match.
ex:
(InstanceNode).mainComponent.key
vs
(ComponentNode).key
tank666
  • February 28, 2024
The key must be the same. Could you share details like videos or file links where you see different keys for the same component?
  • February 28, 2024
The above screen shot is from a file that uses the component.
the above is from the library where the component is.
the component is part of a component set.
tank666
  • February 28, 2024
Sorry, but from these screenshots all I can say is that these are two different components.
Are you sure you selected the correct component in the library file?
