As i mention i keep getting Internal Server error on publishing to community
Why and how to fix it!
Hey @Bojan_Sandic , sorry for the trouble!
1. Can you check if you see the same problem in any other browsers or in the desktop app?
Our supported browsers are Chrome, Firefox, Safari and Edge.
If this happens on desktop app, could you try clearing the cache in your desktop app and try again? More info how to do it here.
2. Does this also happen on another network, like a mobile hotspot?
If it’s just happening on one network, you may need to adjust your proxy VPN or firewall settings as shown in Technical troubleshooting tips or speak to your IT Admins or ISP. Generally for problems affecting a single network we’re not able to troubleshoot as it would require access to your system or network settings.
3. I also checked on our backend that some users had this issue because of tags. The maximum number of tags you should be able to add when publishing file is 12 as reminder.
If the issue still persists, please reach out directly to the support team for help: here
Please include your Figma account email, the URL of the file to the support team that you are trying to publish, and add support-share@figma.com as an editor on this file so they can take a closer look.
Hope this helps!
no its usless reason was you can’t put dash in keywords for examoe “e-sport” it must be “esport” but you need to fix that error…
Thanks for this feedback, we will pass it along to our team for consideration!
