Importing SVG icons
  • May 3, 2024
  • 1319 views
Dad_Zurigo
Got some questions regarding the import of the icons set (300 SVGs)
After dragging an SVG from the file system into Figma, inside a 24x24 frame, there is a couple of layers named “Vector”. This makes it harder to apply styles later. Selecting all layers manually inside the frame and applying FLATTEN SELECTION (CMD+E) for 300 icons would take days.
So, I tried a couple of plugins to bulk flatten them. But the plugins killed the 24px frame/padding: After flattening, they all got different sizes and are no more unified in a 24x24 frame. Maybe there is a way to batch / bulk the 24x24 frame back? Or to flatten only the content inside and leave the 24x24 frame?
Back in the days, I used this cool plugin for sketch:
[Sketch Icons Plugin | Sketch Elements](https://Sketch Icons)
There, I could specify the artboard size during the import process-
Is there anything similar in the Figma world?
  • Figmate
  • May 6, 2024
Hi @Dad_Zurigo, Thanks for reaching out about this.
I’m not entirely sure I’ve grasped what you need, but I’ve done a bit of digging around in our community to see if I could find any relevant plugins. Unfortunately, I haven’t come across the perfect match yet.
I feel there may be others in our community who have had similar experiences, so we would appreciate hearing from other members!
In the meantime, you can also try consulting those plugin owners.
You can find their contact details on the right side of the plugin page: [Support: plugin owner’s email], or you could leave a comment. They might have a workaround for you, and your feedback may lead to new improvements.
Thanks again!
