Importing in code.ts throws error
  • September 26, 2023
  • 1315 views
I am new to writing Figma plugins, however i have started quite a large project. Hence, for code cleanliness i would like to hold some of the functions, types etc. in other files apart from code.ts.
However, when i try to import a function into code.ts to run, from another file, Figma throws an error that it does not recognize the ‘import’ syntax.
Syntax error on line 1: Unexpected token
Is there a way to import a function to the code.ts, so that i dont have to copy the whole codebase into code.ts.
Best answer by tank666
Set up your compiler to bundle the code into a single file.
figma.com
tank666
figma.com
You are a life saver ! Thank you very much !
Miguel Neves
  • March 20, 2025
I followed the guide but then get these errors when compiling to json.:
I have noticed that removing the "./node_modules/@types" from the typeRoots in tsconfig.json no longer launches this error but then will not work with the imports.
[6:55:50 PM] Starting compilation in watch mode...
node_modules/@figma/plugin-typings/index.d.ts:10:9 - error TS2451: Cannot redeclare block-scoped variable 'console'.
10   const console: Console
  node_modules/@types/node/globals.d.ts:157:9
    157     var console: Console;
    'console' was also declared here.
  node_modules/@types/node/console.d.ts:415:19
    415         namespace console {
    and here.
  node_modules/@types/node/console.d.ts:449:13
    449         var console: Console;
    and here.
node_modules/@figma/plugin-typings/index.d.ts:27:9 - error TS2451: Cannot redeclare block-scoped variable 'fetch'.
27   const fetch: (url: string, init?: FetchOptions) => Promise<FetchResponse>
  node_modules/@types/node/globals.d.ts:454:14
    454     function fetch(
    'fetch' was also declared here.
node_modules/@types/node/console.d.ts:415:19 - error TS2451: Cannot redeclare block-scoped variable 'console'.
node_modules/@types/node/console.d.ts:449:13 - error TS2451: Cannot redeclare block-scoped variable 'console'.
node_modules/@types/node/console.d.ts:451:25 - error TS2339: Property 'console' does not exist on type 'typeof globalThis'.
451     export = globalThis.console;
node_modules/@types/node/globals.d.ts:157:9 - error TS2451: Cannot redeclare block-scoped variable 'console'.
node_modules/@types/node/globals.d.ts:454:14 - error TS2451: Cannot redeclare block-scoped variable 'fetch'.
454     function fetch(
[6:55:51 PM] Found 7 errors. Watching for file changes.
