I need help in a prototype!
  • June 7, 2024
  • 129 views
I created an animated slide to confirmation, but instead of a confirmation button, I’d like a pop-up to appear as confirmation on the main screen (after a short delay) once the animation finishes of the slide finish. This is for a presentation today, and I’m new to Figma prototyping. Can anyone offer some quick tips on achieving this interaction?
Context: I’m designing a Figma prototype for a “win a prize” interaction. Here’s the scenario:
  • The user slides a button across the screen.
  • As the button slides, the background changes from gray to green.
  • When the button reaches the end of its track, it turns fully green and displays the text “You won!”.
  • After a brief delay, a pop-up animation with confetti appears, congratulating the user. The pop-up should say “Congratulations!” and then “You won [prize name]!.”
Best answer by Haroll
Hi @Vitor
You can create an interaction between your last frame (the one with the green background and the slides completed) to your congratulation modal.
  1. Set this interaction to : After delay,
  2. Set the delay (time between frame A appear and navigation to frame B)
  3. Set the action to : Open overlay
Hope it helped
Haroll
  • Active Member
  • 273 replies
  • June 7, 2024
Hi @Vitor
Hope it helped
  • June 7, 2024
It helped a lot, thank you very much for taking the time to help me Haroll!
