I'm unable to set the mode for a parent frame
  • December 22, 2023
  • 4 replies
  • 453 views
Paul_Reid
I’ve gone through the variables playground docs and everything seems straightforward, but I cannot assign a mode to a frame. When I look at the example docs, there is a mode switch icon in the layer palette. But when I draw a frame on the canvas, I don’t see it.
I’ve placed a demo file here. I want the red box to change its red variable between light and dark frames.
tank666
  • December 22, 2023
Hey Paul, I looked at your file and everything is fine. You can change the variable mode of any frame as well as the page.
Paul_Reid
  • December 23, 2023
This is weird. I went back to the file today and see that the mode switch icon IS present now. Maybe this is a bug? Or did somebody change something?
When I add a frame and apply a variable color fill, the mode switch appears. Yesterday it did not do that.
Koen
  • March 10, 2025
Odd…. seems I have a similar issue. Though, haven’t found a solution yet.
  • March 11, 2025
Hi ​@Koen
Could you check below?
  • For layers: You can switch their modes if there is at least one variable applied and the variable has multiple modes.
  • For groups, frames, components, component sets, and sections: You can switch their modes if nested layers have at least one variable applied and the variable has multiple modes.
You can see more details here in the article: https://help.figma.com/hc/en-us/articles/15343816063383-Modes-for-variables#h_01HMCXW0AWYJXM2M1JPS9HNGEQ
I hope this helps but if the issue persists, could you share the screen recording so we can follow up?
Thanks!
Toku
