I have checked all the layers in Layers panel. But in Presentation mode, there is icons are showing up which are unwanted
  • February 19, 2024
  • 251 views
The_Yellow_Submarine
I have checked all the layers in Layers panel. But in Presentation mode, there is icons are showing up which are unwanted.
  • February 20, 2024
Hey @The_Yellow_Submarine ,
This is odd! Can you make sure that you haven’t activate the ‘hidden’ layer option to your icon. You can check it in your layer panel (left panel).
Here is how the layer’s visibility works;
You can also toggle a layer’s visibility in the Layers panel. You can toggle layers individually, or hide all child objects in a group or Frame.
  1. Hover over the layer, group or Frame in the Layers panel.
  2. Click on the Screenshot 2024-02-20 at 18.20.31 visibility icon to toggle the layer’s visibility off.
  3. The eye will close and the layer will be hidden in the canvas. It will also appear as inactive (greyed out) in the Layers panel.
  4. Click Screenshot 2024-02-20 at 18.20.58to toggle the layer’s visibility on again.
Please also note when you hide a layer, you won’t be able to select it in the canvas. This includes using the Select layer option in the right-click menu. You can still select the layer in the Layers panel and by showing outlines.
If you need further assistance, feel free to share a copy of your file if you are able to. Or, please reach out directly to the support team with your file so they can investigate: here
Be sure to use the email associated with your Figma account, a link to the file, and share the file with support-share@figma.com (with edit access), so they can take a closer look. Thank you!
