SergioI
May 28, 2025 12:35 PM UTC
I can't see the "detach instance" or "detach component"
I can't see the "detach instance" or "detach component" options anymore. I copied the component to a new document and nothing happened. Copied the component inside the same document and still can't see this options.  I’m admin and editor of this file. Only options are “publish” or “add variant” Anyone knows why is that?
Nellya
Power Member
May 28, 2025 2:28 PM UTC
You can’t detach the main component. You need to copy the instance, detach it and delete the main component. Or use Detach Component plugin.
SergioI
SergioIAuthor
May 28, 2025 2:41 PM UTC
That’s what I tried, copied the component, try to detach the component or the instances and nothing. I don’t see the option on the menu anymore. It is some new behavior? I was able to do it before
Nellya
Power Member
May 28, 2025 2:43 PM UTC
Can you share a screenshot?
SergioI
SergioIAuthor
Jun 3, 2025 11:56 AM UTC
Thank you for your help Nellya, here’s the screenshot, let me know if this is clear enough
Nellya
Power Member
Jun 3, 2025 12:21 PM UTC
That’s the main component. As i mentioned in my first message — you can’t detach it. Your component has variants, so you need to copy all variants, detach them and delete the main component. Or use Detach Component plugin. Here is example ↓
