My issue is that,
  1. I created a variant component (Default and variant1) with text inside it
  2. I used its instances
  3. Then problem is that when I change the font size of variant1 and then then when I preview it wont work
here is the file please check once https://www.figma.com/file/ZyuutY6Q0xlWAYbcT4RX1R/prob?node-id=0%3A1
Did you solve it? I have the same issue
same here. the only solution is to reset all but I lose the texts I’ve already set for that instance.
