Pierre Trochu
May 31, 2025
How to turn a stroke into a boolean property of my component?
Hello,
i’ve created a simple button, with text, padding and autolayout. I’ve turned it into a component. I now want to make the stroke a property for all the variants, that i can turn on and off with a boolean.
However, there is no diamond icon next to the stroke in the right hand panel, so i cannot figure out how to tie it to a prooperty. Is it because the stroke is not a nested item? .
Derek_Avila_P
You can add a rectangle shape to your autolayout frame, set its position to “Ignore autolayout”, manually resize it to the entire autolayout size (you could also use the plugin “Resize to Frame” → “Both” and set its constrains to “Left+Right” and “Top+Bottom” then asign this layer visibility to a boolean property.
sezer
Every property under the “Appearance” section — Fill, Stroke, and Effects — should be able to be added as a standalone nested item. If Figma made a small improvement here, it would be incredible. We’re honestly tired of creating patchwork solutions.
Sandon
For those still looking for a way to do this: Create two components, one with borders and one without. Add a variant property, name it “Border” and set the Values = True/False. Select the components that have borders, set to True. For those that don’t, set to false.
